AD970X评估板
消耗积分:0 | 格式:pdf | 大小:235.49KB | 2021-05-18
王军
分享资料个
This version (05 Mar 2021 03:53) was approved by Shine Cabatan.The Previously approved version (05 Mar 2021 03:51) is available.Diff
EVALUATING THE AD9704/AD9705/AD9706/AD9707 DIGITAL-TO-ANALOG CONVERTER
Preface
This user guide describes both the hardware and software setup needed to acquire data capture from AD9704-DPG2-EBZ/AD9705-DPG2-EBZ/AD9706-DPG2-EBZ/AD9707-DPG2-EBZ evaluation board to characterize AD9704/AD9705/AD9706/AD9707 8-/10-/12-/14-bit 175Msps high-speed digital-to-analog converter.
Typical Setup
Figure 1. EVAL-AD970x Evaluation Setup
Tip: Click on any picture in this guide to open an enlarged version.
Helpful Files:
Software Needed:
Hardware Needed:
Quick Start Guide
  1. Attach AD9704-DPG2-EBZ/AD9705-DPG2-EBZ/AD9706-DPG2-EBZ/AD9707-DPG2-EBZ to SDP-H1 FMC connector using the AD-DAC-FMC-ADP adapter board. Connect continuous wave generator for clock input to J10 and DAC output from S4 to a signal/spectrum analyzer. Connect the evaluation board to PC via USB. Refer to Figure 1.
  2. Connect SDP-H1 to PC via USB and to a 12V 1A power supply.
  3. Set clock input to 175MHz and 13dBm.
  4. Open ACE. The board will be automatically recognized by the software. Otherwise, install the plugin for AD9707.
  5. Start DPG Lite or DPG Downloader. At the SDP-H1 part of the software, the device part number and clock frequency should be displayed.
  6. In ACE, apply the default values in the Initial Configuration wizard as shown in Figure 2.
    Figure 2. ACE Initial Configuration Wizard for EVAL-AD9707
  7. In DPG Lite or DPG Downloader, from the Add Generator Waveforms pulldown menu select Single Tone and apply the settings as shown in Figure 3. Set the desired frequency to 20 MHz. Set DAC resolution to the DAC’s number of bits (14 for AD9707, 12 for AD9706, and so on). Check the Unsigned Data box.
    Figure 3. DPG Lite session for EVAL-AD9707
  8. Select the tone from the Data Vector pulldown menu.
  9. Press the download arrow and then the play button. The spectrum similar to Figure 4 should appear in the signal/spectrum analyzer.
    Figure 4. EVAL-AD9707 FFT for Fdac=175MHz, Fout=20MHz
评论(0)
发评论
下载排行榜
