EVAD912 AD9912 评估板
消耗积分:0 | 格式:pdf | 大小:496.08KB | 2021-06-04
万物死
分享资料个
EVAL-AD9912 EVAL-AD9912 AD9912 评估板 | Analog Devices EVAL-AD9912 本页面提供有关评估AD9912的评估板文档和订购信息。 AD9912 评估板 本页面提供有关评估AD9912的评估板文档和订购信息。
  • Flexible system clock input accepts crystal, crystal oscillator, or external reference clock
  • Dedicated pad for mounting crystal or crystal oscillator
  • DAC output easily accessible via SMA connector
  • SMA connectors provided for external reconstruction filter
  • Easy to use Windows graphical user interface
  • Software control of all AD9912 features
  • Power supplies that are easily separated
  • Connection via USB port
  • Dedicated SMA connectors for CMOS, DAC, and HSTL outputs
  • Residual phase noise at 250 MHz
    10 Hz offset: −113 dBc/Hz
    1 kHz offset: −133 dBc/Hz
    100 kHz offset: −153 dBc/Hz
    40 MHz offset: −161 dBc/Hz
(analog)
评论(0)
发评论
下载排行榜
