L293/L293D/L293DD pdf datashee
消耗积分:0 | 格式:rar | 大小:333 | 2009-02-10
名士流
分享资料个
The Device is a monolithic integrated high voltage,high current four channel driver designed to accept standard DTL or TTL logic levels and drive inductive loads (such as relays solenoides, DC and stepping motors) and switching power transistors.
To simplify use as two bridges each pair of channels
is equipped with an enable input. A separate
supply input is provided for the logic, allowing operation
at a lower voltage and internal clamp diodes are included.
This device is suitable for use in switching applications at frequencies up to 5 kHz.
评论(0)
发评论
下载排行榜
