基于EVAL-ADF7021DBJZ射频收发器的参考设计
消耗积分:0 | 格式:pdf | 大小:324.49KB | 2021-09-10
维生素B2
分享资料个
说明
  • EVAL-ADF7021DBJZ, Daughter Board based on ADF7021 426 to 435 MHz ISM band transceiver with External Inductor VCO. The ADF7021 is a 2FSK/3FSK/4FSK transceiver that is designed for operation in the licensed and unlicensed VHF/UHF bands from 80 to 940 MHz. The daughter-board contains all the required components for operation of the radio, including loop filter, output matching, antenna and connector to mother board
主要特色
  • Communication Standard
    2FSK/3FSK/4FSK
  • Operating Frequency
    426 to 435 MHz
评论(0)
发评论
下载排行榜
