Homebridge插件可在Apple HomeKit中使用RuuviTags
消耗积分:0 | 格式:zip | 大小:0.00 MB | 2022-04-21
李凤津
分享资料个
授权协议 Readme
开发语言 JavaScript
操作系统 跨平台
软件类型 开源软件
所属分类 其他开源物联网
软件简介
homebridge-ruuvitag
With this Homebridge plugin you can use RuuviTags with Apple HomeKit.
Updates
Installation
First, install Avahi (Homebridge needs this), Homebridge and this plugin (you also need Node.js installed):
sudo apt-get install libavahi-compat-libdnssd-dev
sudo npm i -g homebridge
sudo npm i -g homebridge-ruuvitag
Find out Ruuvitag ID's
You can find out Ruuvitag ID's by installing and running ruuvitag-debug:
sudo npm -g i ruuvitag-debug
ruuvitag-debug
Config
Create a ~/.homebridge/config.json file (change ID's and add/remove tags as necessary):
  "bridge": {
    "name": "Ruuvi",
    "username": "CC:22:3D:E3:CE:30",
    "port": 51826,
    "pin": "031-45-154"
  "description": "RuuviTag bridge",
  "accessories": [
      "accessory": "Ruuvitag",
      "name": "Ruuvi 1",
      "id": "ca67bf52ca12"
      "name": "Ruuvi 2",
      "id": "fa81b4c6a891"
      "name": "Ruuvi 3",
      "id": "ac67df12bb34"
Socket option
You can listen to RuuviTag update events emitted from a socket server instead of using Bluetooth. This is signalled by adding a configuration parameter for the accessory.
"socket": "http://raspberrypi.local:8787"
Run
Now you can run Homebridge:
homebridge
Start on startup
Install pm2:
npm -g i pm2
Start with pm2 and save as daemon:
pm2 start homebridge
pm2 save
pm2 startup
Supported features
  • temperature
  • humidity
  • battery level
  • battery level alert
  • heat alert
  • cold alert
  • high humidity alert
  • low humidity alert
  • motion alert
评论(0)
发评论
下载排行榜
