TLC5615资料
消耗积分:2 | 格式:pdf | 大小:733KB | 2014-12-01
杨利峰
分享资料个
The TLC5615 is a 10-bit voltage output digital-to-analog converter (DAC) with a buffered reference input (high impedance)。The DAC has an output voltage range that is two times the reference voltage, and the DAC is monotonic。 The device is simple to use, running from a single supply of 5V。 A power-on-reset function is incorporated to ensure repeatable start-up conditions。
评论(0)
发评论
下载排行榜
