So You Want Wi-Fi?
开发商在产品实现Wi-Fi是一个选择的802.11个标准,包括802.11a,b,g,n或组合标准。那么你应该选择哪一个呢?让我们回顾一下这些技术的优点和折衷,以帮助您进行有教养的选择。
Wi-Fi背景
7亿多人使用的Wi-Fi是增长最快的技术之一。它是由NCR公司/ AT&T公司于1991在荷兰发明的。“Wi-Fi”不是一个技术术语,但通常用来指IEEE 1997成立的802.11个标准。该标准在过去15年中不断发展,以支持在快速增长的市场中应用更多的应用程序。1999,成立Wi-Fi联盟以促进Wi-Fi的发展,并通过使用Wi-Fi技术认证产品以确保业界的成功。
802.11b
802.11b was established by the IEEE in 1999 to improve the data rate of the original 802.11 standard created in 1997. The original 802.11 standard supported a maximum data rate of 2 Mbps. This standard is no longer supported by the industry and therefore is not relevant to this analysis. All 802.11/Wi-Fi standards use the unlicensed radio spectrum. 802.11b supports only the license-free ISM band around 2.4 GHz. The maximum data rate of 802.11b is 11 Mbps, which is the slowest relative to the other 802.11 standards. Currently, the main advantages of 802.11b are cost of chipsets and signal integrity, which is inherently due to high sensitivity at lower data rates.
