General Description
The FP7180 is an average current mode control LED driver IC operating in a constant off-time
mode.FP7180 does not produce a peak-to-average error,and therefore greatly improves accuracy,
line and load regulation of the LED current without any need for loop compensation or high-side
current sensing.The output LED current accuracy is +2%.
TheFP7180canbepoweredfroman8.0- :100Vsupply.APWM &lineardimminginputis
provided that accepts an extemal control TTL compatible signal.The output current can be
programmedbyanintemal250mVreference.orcontrolledexternallythrougha0.2- 1.5Vdimming
input.
