双输入网络时钟发生器/同步器ad9549数据表
消耗积分:0 | 格式:rar | 大小:1.11 MB | 2017-10-19
分享资料个
  The AD9549 provides synchronization for many systems, including synchronous optical networks (SONET/SDH)。 The AD9549 generates an output clock, synchronized to one of two external input references. The external references may contain significant time jitter, also specified as phase noise. Using a digitally controlled loop and holdover circuitry, the AD9549 continues to generate a clean (low jitter), valid output clock during a loss of reference condition, even when both references have failed. The AD9549 operates over an industrial temperature range of −40°C to +85°C.
评论(0)
发评论
下载排行榜
