CSR8610A04 DataSheet
消耗积分:0 | 格式:pdf | 大小:1731KB | 2017-12-06
黄晓敏
分享资料个
CSR蓝牙8645
  80MHz RISC MCU and 80MIPS Kalimba DSP ■ Internal ROM, serial flash memory and EEPROM interfaces ■ Mono codec with 1 analogue input and 1 digital microphone (MEMS) interface ■ Radio includes integrated balun ■ CSR‘s latest CVC technology for narrowband and wideband voice connections including wind noise reduction ■ Wideband speech supported by HFP v1.6 profile and mSBC codec ■ Voice recognition support for answering a call, enables true hands-free use ■ Multipoint HFP connection to 2 phones for voice ■ Multipoint A2DP connection enables a headset (A2DP) connection to 2 A2DP source devices for music playback ■ Secure simple pairing, CSR’s proximity pairing and CSR‘s proximity connection ■ Audio interfaces: I²S and PCM ■ Serial interfaces: UART, USB 2.0 (full-speed), I²C and SPI ■ Integrated dual switch-mode regulators, linear regulators and battery charger ■ External crystal load capacitors not required for typical crystals ■ 3 LED outputs ■ 68‑ball VFBGA 5.5 x 5.5 x 1mm 0.5mm pitch ■ Green (RoHS compliant and no antimony or halogenated flame retardants)
评论(0)
发评论
下载排行榜
