IDT2305 pdf datasheet (3.3V ZE
消耗积分:0 | 格式:rar | 大小:333 | 2008-08-06
张伟
分享资料个
The IDT2305 is a high-speed phase-lock loop (PLL) clock buffer,
designed to address high-speed clock distribution applications. The zero
delay is achieved by aligning the phase between the incoming clock and
the output clock, operable within the range of 10 to 133MHz.
The IDT2305 is an 8-pin version of the IDT2309. IDT2305 accepts one
reference input, and drives out five low skew clocks. The -1H version of this
device operates, up to 133MHz frequency and has a higher drive than the
-1 device. All parts have on-chip PLLs which lock to an input clock on the
REF pin. The PLL feedback is on-chip and is obtained from the CLKOUT
pad. In the absence of an input clock, the IDT2305 enters power down. In
this mode, the device will draw less than 25μA, the outputs are tri-stated,
and the PLL is not running, resulting in a significant reduction of power.
The IDT2305 is characterized for both Industrial and Commercial
operation.
评论(0)
发评论
下载排行榜
