基于TGP2109-SM下的 8-12 6-Bit Digital Phase Shifter
消耗积分:0 | 格式:pdf | 大小:1.03 MB | 2018-07-25
duke刘
分享资料个
  Applications
  • X-Band Radar
  • Satellite Communication Systems
  General Description
  The Qorvo TGP2109-SM is a packaged 6-bit digital phase shifter fabricated on Qorvo’s high performance 0.15μm GaAs pHEMT process. It operates over 8 to 12 GHz and provides 360° of phase coverage with a LSB of 5.625°。 It also achieves a low RMS phase error of 4° with 6 dB of insertion loss.
  The TGP2109-SM was developed for simply system integration. It uses positive only switch logic eliminating the need for a negative voltage rail. In addition, both ports are matched to 50 ohms with DC blocking capacitors. Ease of use along with low insertion loss and a high degree of resolution makes the TGP2109-SM ideally suited for a variety of x-band phased array applications including commercial and military radars and phase array communication systems.
  The device is lead-free and RoHS compliant.
  Evaluation Boards are available upon request.
评论(0)
发评论
下载排行榜
