基于TGP2105-SM下的6-18 GHz 6-Bit Digital Phase Shifter (+Vc)
消耗积分:0 | 格式:pdf | 大小:0.95 MB | 2018-07-25
好名字
分享资料个
  Applications
  • Phased Array Antenna Systems
  • Satellite Communication Systems
  • Electronic Warfare
  General Description
  TriQuint’s TGP2105-SM is a packaged 6-bit digital phase shifter, fabricated on TriQuint’s high performance 0.15μm GaAs pHEMT process. It operates over 6 to 18 GHz and provides 360° of phase coverage with a LSB of 5.625°。 It also achieves a low RMS phase error of 4° with 8 dB of insertion loss over all states.
  The TGP2105-SM uses positive switch logic, eliminating the need for a negative voltage rail. That, along with low insertion and a high degree of resolution makes the TGP2105-SM ideally suited for a variety of wideband phased array applications, including commercial and military radars, satellite-based communication systems and electronic warfare.
  The device is lead-free and RoHS compliant.
  Evaluation Boards are available upon request.
评论(0)
发评论
下载排行榜
