基于TGP2615 下的15- to 19-GHz 6-Bit Digital Phase Shifter
消耗积分:0 | 格式:pdf | 大小:0.37 MB | 2018-07-25
分享资料个
  Applications 
  Phased-Array Radar
   Satellite Communications
  General Description
  TriQuint’s TGP2615 is a 6-bit digital phase shifter fabricated on TriQuint’s high-performance 0.15-μm GaAs pHEMT process. It operates over 15 to 19 GHz, and provides 360° of phase coverage with a LSB of 5.625°。 It also achieves a low RMS phase error of 4°, with 7-dB average insertion loss over all states.
  The TGP2615 uses positive single-control-line switch logic, eliminating the need for a negative voltage rail or complimentary logic. This, combined with low insertion loss and a high degree of resolution makes the TGP2615 ideally suited for applications in phased-array radar and satellite communications.
  The device is lead-free and RoHS compliant
评论(0)
发评论
下载排行榜
