基于RFSA2644下的SERIAL CONTROLLED DIGITAL STEP ATTENUATOR 50MHz TO 4000MHz 6-BIT 0.5dB LSB
消耗积分:0 | 格式:pdf | 大小:1.17 MB | 2018-07-25
刘洋
分享资料个
  Product Description
  RFMD’s RFSA2644 is a 6-bit digital step attenuator (DSA) that features high linearity over the entire 31.5dB gain control range with excellent step accuracy in 0.5dB steps. The RFSA2644 is programmed via a serial mode control interface that is both 3V and 5V compatible. The RFSA2644 also offers a rugged Class 1C HBM ESD rating via on-chip ESD circuitry. The MCM package is footprint compatible with most 24-pin, 4mm x 4mm, QFN packages.
评论(0)
发评论
下载排行榜
