LM2468 pdf datasheet (Monoloth
消耗积分:0 | 格式:rar | 大小:777 | 2008-09-19
申根换
分享资料个
LM2468 Monolothic Triple 14nS High Gain CRT Driver
General Description
The LM2468 is an integrated high voltage CRT driver circuit
designed for use in color monitor applications. The IC contains
three high input impedance wide band amplifiers,
which directly drive the RGB cathodes of a CRT. Each
channel has its gain internally set to -20 and can drive CRT
capacitive loads as well as resistive loads present in other
applications, limited only by the package’s power dissipation.
The IC is packaged in an industry standard 9 lead TO-220
molded plastic package.
评论(0)
发评论
下载排行榜
