KMZ43T pdf datasheet (Magnetic
消耗积分:3 | 格式:rar | 大小:350 | 2008-10-13
分享资料个
The KMZ43T is a sensitive magnetic field sensor, employing the magnetoresistive effect of thin-film permalloy. The sensor contains two galvanic separated Wheatstone bridges, at a relative angle of 45Deg to one another.
A rotating magnetic field in the x-y plane will produce two independent sinusoidal output signals, one a function of +cos(2α)
评论(0)
发评论
下载排行榜
