INA117 pdf datasheet (High Com
消耗积分:5 | 格式:rar | 大小:555 | 2008-10-14
王芳
分享资料个
The INA117 is a precision unity-gain difference
amplifier with very high common-mode input voltage
range. It is a single monolithic IC consisting of a
precision op amp and integrated thin-film resistor
network. It can accurately measure small differential
voltages in the presence of common-mode signals up
to ±200V. The INA117 inputs are protected from
momentary common-mode or differential overloads
up to ±500V.
In many applications, where galvanic isolation is not
essential, the INA117 can replace isolation amplifiers.
This can eliminate costly isolated input-side power
supplies and their associated ripple, noise and quiescent
current. The INA117’s 0.001% nonlinearity and
200kHz bandwidth are superior to those of conventional
The INA117 is available in 8-pin plastic mini-DIP and
SO-8 surface-mount packages, specified for the –40°C
to +85°C temperature range. The metal TO-99 models
are available specified for the –40°C to +85°C and
–55°C to +125°C temperature range.
评论(0)
发评论
下载排行榜
