library ieee: use ieee.std_logic_1164.all; entity air_conditioner is port(clk:in std_ulogic; temp_high:in std_ulogic; temp_low:in std_ulogic; heat:out std_ulogic; cool:out std_ulogic); end air_conditioner; achitecture style_b of air_conditioner is type state_type is (just_right,too_cold,too_hot); attribute sequential_encoding of state_type:type is "00 01 10"; signal stvar:state_type; attribute state_vector:string; arrribute state_vector of style_b:architecture is "stvar"; begin controllerl:process begin wait until clk='1'; if(temp_low='1')then stvar<=too_cold; elsif(temp_high='1')then stvar<=too_hot; else stvar<=just_right; end if; case stvar is when just_right=>heat<='0'; cool<='0'; when too_cold=>heat<='1'; cool<='0'; when too_hot=>heat<='0'; cool<='1'; end case; end process controllerl; end style_b;
