AME9172 pdf datasheet (Bus Ter
消耗积分:2 | 格式:rar | 大小:333 | 2008-12-01
学电超人
分享资料个
The AME9172 is a voltage regulator which could convert
the input voltage ranging from 1.5V to 6V to an output
voltage that user settled. The regulator can provide sourcing
or sinking current. The AME9172 used in conjunction
with series termination resistors, provides an excellent
voltage source for active termination schemes of high
speed transmission lines as those seen in high speed
memory buses and distributed backplane designs.
The voltage output of the regulator can be used as a
termination voltage for DDR SDRAM.
Current limits in both sourcing and sinking mode, plus
on-chip thermal shutdown make the circuit tolerant of the
output fault conditions.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
