TCM80/TCM80A pdf datasheet (CE
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-04
贾飞世
分享资料个
The TCM8000 is configured using a three-wire digital interface. Eight-bit words, comprised of four address and four data bits, are applied in serial to DATA and clocked into the device on the rising edge of DCLK. The data is transferred to internal registers by pulsing the LOAD signal high (see Figure 1). All internal registers are reset low on power up.
评论(0)
发评论
下载排行榜
