RT8020 pdf datasheet (Dual Hig
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-12
听风说梦
分享资料个
The RT8020 is a dual high-efficiency Pulse-Width-
Modulated (PWM) step-down DC-DC converter. It is
capable of delivering 1A output current over a wide input
voltage range from 2.5V to 5.5V, the RT8020 is ideally
suited for portable electronic devices that are powered
from 1-cell Li-ion battery or from other power sources within
the range such as cellular phones, PDAs and other handheld
devices.
Two operational modes are available : PWM/Low-Dropout
auto-switch and shutdown modes. Internal synchronous
rectifier with low RDS(ON) dramatically reduces conduction
loss at PWM mode. No external Schottky diode is
required in practical application.
The RT8020 enters Low-Dropout mode when normal PWM
cannot provide regulated output voltage by continuously
turning on the upper PMOS. The RT8020 enter shutdown
mode and consumes less than 0.1mA when EN pin is pulled
low.
The sw
评论(0)
发评论
下载排行榜
