OPA2650 pdf datasheet (Dual Wi
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-18
分享资料个
The OPA2650 is a dual, low power, wideband voltage
feedback operational amplifier. It features a high bandwidth
of 360MHz as well as a 12-bit settling time of
only 20ns. The low distortion allows its use in communications
applications, while the wide bandwidth and
true differential input stage make it suitable for use in
a variety of active filter applications. Its low distortion
gives exceptional performance for telecommunications,
medical imaging and video applications.
The OPA2650 is internally compensated for unitygain
stability. This amplifier has a fully symmetrical
differential input due to its “classical” operational
amplifier circuit architecture. Its unusual combination
of speed, accuracy and low power make it an outstanding
choice for many portable, multi-channel and other
high speed applications, where power is at a premium.
The OPA2650 is also available in single (OPA650)
and quad (OPA4650) configurations.
评论(0)
发评论
下载排行榜
