ISL59830 pdf datasheet (revolu
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-20
分享资料个
The ISL59830 is a revolutionary device that allows true singlesupply
operation of video amplifiers. The device runs off a
single 3.3V supply and generates the required negative
voltage internally. This allows for DC-accurate coupling of
video onto a 75Ω double-terminated line. Since the buffers
have an integrated 6dB gain, no external gain setting resistors
are required. An input reference voltage can be supplied to
shift the analog video level down by an amount equal to the
reference (typically 0.6V).
评论(0)
发评论
下载排行榜
