X80120, X80121 pdf datasheet(V
消耗积分:3 | 格式:rar | 大小:318 | 2008-12-23
胡秋阳
分享资料个
The X80120 is a voltage supervisor/sequencer with two built
in voltage monitors. This allows the designer to monitor up to
two voltages and sequence up to three events.
Low voltage detection circuitry protects the system from
power supply failure or “brown out” conditions, resetting the
system and resequencing the voltages when any of the
monitored inputs fall below the minimum threshold level. The
RESET pin is active until all monitored voltages reach proper
operating levels and stabilize for a selectable period of time.
Five common low voltage combinations are available,
however, Intersil’s unique circuits allow the any voltage
monitor threshold to be reprogrammed for special needs or
for applications requiring higher precision.
评论(0)
发评论
下载排行榜
