The HSP43481 is a video-speed Digital Filter (DF) designed to efficiently implement vector operations such as FIR digital filters. It is comprised of four filter cells cascaded internally and a shift-and-add output stage, all in a single integrated circuit. Each filter cell contains an 8 x 8 multiplier, three decimation registers and a 26-bit accumulator which can add the contents of any filter cell accumulator to the output stage accumulator shifted right by eight-bits. The HSP43481 has a maximum sample rate of 30MHz. The effective multiplyaccumulate (MAC) rate is 120MHz.
