HSP9501 pdf datasheet(Programm
消耗积分:3 | 格式:rar | 大小:414 | 2009-01-03
张杰
分享资料个
The HSP9501 is a 10-Bit wide programmable data buffer designed for use in high speed digital systems. Two different modes of operation can be selected through the use of the MODSEL input. In the delay mode, a programmable data pipeline is created which can provide 2 to 1281 clock cycles of delay between the input and output data. In the data recirculate mode, the output data path is internally routed back to the input to provide a programmable circular buffer.
评论(0)
发评论
下载排行榜
