82C87H pdf datasheet (CMOS Oct
消耗积分:5 | 格式:rar | 大小:233 | 2009-01-09
vinww特烦恼
分享资料个
The Intersil 82C87H is a high performance CMOS Octal
Transceiver manufactured using a self-aligned silicon gate
CMOS process (Scaled SAJI IV). The 82C87H provides a full
eight-bit bi-directional bus interface in a 20 pin package. The
Transmit (T) control determines the data direction. The active
low output enable (OE) permits simple interface to the
80C86, 80C88 and other microprocessors. The 82C87H has
gated inputs, eliminating the need for pull-up/pull-down resistors
and reducing overall system operating power dissipation.
The 82C87H provides inverted data at the outputs.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
