HM-6514 pdf datasheet (1024 x
消耗积分:3 | 格式:rar | 大小:233 | 2009-01-09
分享资料个
The HM-6514 is a 1024 x 4 static CMOS RAM fabricated
using self-aligned silicon gate technology. The device utilizes
synchronous circuitry to achieve high performance and
low power operation.
On-chip latches are provided for addresses allowing efficient
interfacing with microprocessor systems. The data output
can be forced to a high impedance state for use in expanded
memory arrays.
Gated inputs allow lower operating current and also eliminate
the need for pull up or pull down resistors. The
HM-6514 is a fully static RAM and may be maintained in any
state for an indefinite period of time.
Data retention supply voltage and supply current are guaranteed
over temperature.
评论(0)
发评论
下载排行榜
