HS-245RH, HS-246RH, HS-248RH p
消耗积分:3 | 格式:rar | 大小:344 | 2009-01-09
Petc
分享资料个
The HS-245RH/246RH/248RH radiation hardened triple line
transmitter and triple line receivers are fabricated using the
Intersil dielectric isolation process. These parts are identical in
pinout and function to the original HD-245/246/248. They are
also die size and bond pad placement compatible with the
original parts for those customers who buy dice for hybrid
assembly.
Each transmitter-receiver combination provides a digital
interface between systems linked by 100Ω twisted pair,
shielded cable. Each device contains three circuits
fabricated within a single monolithic chip. Data rates greater
than 15MHz are possible depending on transmission line
loss characteristics and length.
The transmitter employs constant current switching which
provides high noise immunity along with high speeds, low
power dissipation, low EMI generation and the ability to
drive high capacitance loads. In addition, the transmitters
can be turned “off” allowing several transmitters to timeshare
a single line.
评论(0)
发评论
下载排行榜
