ISDB-T “1SEG.” Hand-Held Signal Analyzer is the world’s first portable test solution for Real-Time ISDB-T ‘1Seg’ signal Analysis and Capture. ISA1000 enables you to analyze and interpret the live or previously recorded transport stream of ISDB-T 1SEG. It fully supports ARIB STD-B10 & B31 standard and 1SEG. Information analysis. Also, you can capture 1SEG. ISDB-T signal according to each region and channel with simple operation of ISA1000. And you can play this captured TS with DTVinteractive’s ISDB-T Signal Generator (ISG500) to test performance of your ‘1SEG.’ receiver. For your ISDB-T development, ISA1000 will be the most suitable test solution integrated with ISG500.
