ISL97651 pdf datasheet (4-Chan
消耗积分:2 | 格式:rar | 大小:555 | 2009-01-16
小组店小二
分享资料个
The ISL97651 represents a high power, integrated LCD
supply IC targeted at large panel LCD displays. The
ISL97651 integrates a high power, 4.4A boost converter for
AVDD generation, an integrated VON charge pump, a VOFF
charge pump driver, VON slicing circuitry and a buck
regulator with 2A switch for logic generation.
The ISL97651 have been designed for ease of layout and
low BOM cost. Supply sequencing is integrated for both
AVDD -> VOFF -> VON and AVDD/VOFF -> VON sequences.
The TFT power sequence uses a separate enable to the
logic buck regulator for maximum flexibility.
评论(0)
发评论
下载排行榜
