ByteBlasterMV Parallel Port Do
消耗积分:5 | 格式:rar | 大小:433 | 2009-01-16
20615
分享资料个
The ByteBlasterMV parallel port download cable (ordering code:
PL-BYTEBLASTERMV) is a hardware interface to a standard PC parallel
port (also known as an LPT port). This cable drives configuration data to
APEX 20K, FLEX 10K (including FLEX 10KA and FLEX 10KE),
FLEX 8000, and FLEX 6000 devices, as well as programming data to
MAX 9000, MAX 7000S, MAX 7000A, and MAX 3000A devices. Because
design changes are downloaded directly to the device, prototyping is easy
and multiple design iterations can be accomplished in quick succession.
See Figure 1.
评论(0)
发评论
下载排行榜
