摘要介绍了基于PLC 的水电站橡胶坝监控系统的设计思想,并详细提出了该控制系统的结构、PLC 的硬件组成和软件设计。
关键词监控系统可编程控制器水电站橡胶坝WinCC
Abstract The design concept of the PLC based rubber dam monitoring system in water power station is introduced. The system architecture,configuration of hardware of PLC,and software design are described in detail.
Keywords Monitoring system Programmable logic controller Water power station Rubber dam WinCC
橡胶坝运行概述
该橡胶坝的坝体由水充胀橡胶坝袋而构成,跨于河道两岸之上。坝袋的最大高度4.5m,坝长100m,由两台55kW 电动机拖动1000m3 / h 的水泵进行充、排水,水管内径0.5m。阀、泵、管路与坝体情况如图1所示。
