AD7091R FMC-SDP转接器和评估板/Xilinx KC705参考设计
消耗积分:2 | 格式:pdf | 大小:304.38KB | 2021-04-21
分享资料个
This version (10 Feb 2021 10:45) was approved by Istvan Csomortani.The Previously approved version (09 Jan 2021 00:48) is available.Diff
AD7091R FMC-SDP Interposer & Evaluation Board / Xilinx AC701 Reference Design
Supported Devices
Evaluation Boards
Overview
This document presents the steps to setup an environment for using the EVAL-AD7091RSDZ evaluation board together with the Xilinx KC705 FPGA board and the Xilinx Embedded Development Kit (EDK). Below is presented a picture of the EVAL-AD7091RSDZ Evaluation Board with the Xilinx KC705 board.
For component evaluation and performance purposes, as opposed to quick prototyping, the user is directed to use the part evaluation setup. This consists of:
  • 1. A controller board like the SDP-B ( EVAL-SDP-CS1Z)
  • 2. The component SDP compatible product evaluation board
  • 3. Corresponding PC software ( shipped with the product evaluation board)
The SDP-B controller board is part of Analog Devices System Demonstration Platform (SDP). It provides a high speed USB 2.0 connection from the PC to the component evaluation board. The PC runs the evaluation software. Each evaluation board, which is an SDP compatible daughter board, includes the necessary installation file required for performance testing.
Note: it is expected that the analog performance on the two platforms may differ.
28 Sep 2012 10:32 · Adrian Costina
Below is presented a picture of SDP-B Controller Board with the EVAL-AD7091RSDZ Evaluation Board.
The AD7091R is a 12-bit successive approximation analog-to-digital converter (ADC) that offers ultralow power consumption (typically 349 µA at 3 V and 1 MSPS) while achieving fast throughput rates (1 MSPS with a 50 MHz SCLK). Operating from a single 2.7 V to 5.25 V power supply, the part contains a wide bandwidth track-and-hold amplifier that can handle input frequencies in excess of 7 MHz. The AD7091R also features an on-chip conversion clock, accurate reference, and high speed serial interface.
The EVAL-AD7091RSDZ evaluation board is a member of a growing number of boards available for the SDP. They were designed to help customers evaluate performance or quickly prototype new AD7091R circuits and reduce design time.
More information
Getting Started
The first objective is to ensure that you have all of the items needed and to install the software tools so that you are ready to create and run the evaluation project.
Required Hardware
Required Software
  • Xilinx ISE 14.6
  • A UART terminal (Tera Term/Hyperterminal/Termite), baud rate 115200.
Downloads
Run the Demonstration Project
Hardware Setup
Before connecting the ADI evaluation board to the Xilinx KC705 make sure that the VADJ_FPGA voltage of the KC705 is set to 3.3V. For more details on how to change the setting for VADJ_FPGA visit the Xilinx KC705 product page.
  • Use the FMC-SDP interposer to connect the ADI evaluation board to the Xilinx KC705 board on the FMC LPC connector.
  • Connect the JTAG and UART cables to the KC705 and power up the FPGA board.
  • Power the ADI evaluation board.
  • Start a UART terminal and set the baud rate to 115200 bps.
The next step is to setup the software project.
Software Project Setup
The next steps should be followed to recreate the software project of the reference design:
  • Copy the folder ../fpgahdl_xilinx/cf_lib and ../fpgahdl_xilinx/cf_sdp_adc/cf_ad7091_ac701 to your working directory
  • Open a Xilinx SDK and setup your workspace to %Working directory%/cf_ad7091_ac701/SDK/SDK_Workspace
  • In the SDK select the File→Import menu option to import the software project into your workspace.
Import Projects
  • In the Import window select the General→Existing Projects into Workspace option.
Existing Projects Import
  • In the Import Projects window select the %Working directory%/cf_ad7091_ac701/ folder as root directory and verify if all the three project (hw, bsp, sw) are checked.
Selecting Existing Projects
  • The Project Explorer window now shows the projects that exist in the workspace without software files.
Project Explorer
  • Now you have to add the source files to your project. You can download all the source files for the current reference project using the links from the Downloads section. List of source files for the current project is:
    • Driver files : ad7091.h and ad7091.c
    • Platform specific files : Communication.h, Communication.c, TIME.h and TIME.c
    • ADC specific files : main.c and xdma_config.h
  • All these files must be copied into the %Working directory%/cf_ad7091_ac701/SDK/SDK_Workspace/sw/src/ folder.
  • The SDK should automatically build the project and the Console window will display the result of the build. If the build is not done automatically, select the Project→Build Automatically menu option.
  • If the project was built without any errors, you need to download the data capture script, from here. Copy the Data_capture folder to your working directory.
  • Run the data_capture.bat script. If the acquisition is finished with success, it should appear a file called Acquisition.csv with the result of the conversion.
Acquisition Finished
  • By default the length of a transaction is 16k samples. The input signal used in this reference design was a 10 Khz sine wave.
Acquisition Result
More information
28 May 2012 15:18
评论(0)
发评论
下载排行榜
