The ISL21060 FGA™ voltage references are low power, high precision voltage references fabricated on Intersil’s proprietary Floating Gate Analog technology. A new disable feature allows the device to shut down the output and reduce supply current drain from 15μA operating to <500nA. The ISL21060 family features guaranteed initial accuracy as low as ±1.0mV with drift down to 10ppm/°C. Noise is typically 10μVP-P (10Hz BW). This combination of high initial accuracy, low power and low output noise performance of the ISL21060 enables versatile high performance control and data acquisition applications with low power consumption.
