ISL6754 pdf datasheet (ZVS Ful
消耗积分:10 | 格式:rar | 大小:433 | 2009-01-18
鼠爱米
分享资料个
The ISL6754 is a high-performance extension of the Intersil
family of zero-voltage switching (ZVS) full-bridge PWM
controllers. Like the ISL6752, it achieves ZVS operation by
driving the upper bridge FETs at a fixed 50% duty cycle while
the lower bridge FETs are trailing-edge modulated with
adjustable resonant switching delays.
Adding to the ISL6752’s feature set are average current
monitoring and soft-start. The average current signal may be
used for average current limiting, current sharing circuits and
average current mode control. Additionally, the ISL6754
supports both voltage- and current-mode control.
The ISL6754 features complemented PWM outputs for
synchronous rectifier (SR) control. The complemented
outputs may be dynamically advanced or delayed relative to
the PWM outputs using an external control voltage.
This advanced BiCMOS design features precision deadtime
and resonant delay control, and an oscillator adjustable to
2MHz operating frequency. Additionally, Multi-Pulse
Suppression ensures alternating output pulses at low duty
cycles where pulse skipping may occur.
下载资料需要登录,并消耗一定积分。
评论(1)
发评论
fushao 2020-09-23
0 回复 举报
我想看看。 收起回复
下载排行榜
全部1条评论
