KAD2708/KAD2708L pdf datasheet
消耗积分:2 | 格式:rar | 大小:433 | 2009-01-19
张静
分享资料个
The Intersil KAD2708L is the industry’s lowest power, 8-bit,
350MSPS, high performance Analog-to-Digital converter. It is
designed with Intersil’s proprietary FemtoCharge™ technology
on a standard CMOS process. The KAD2708L offers high
dynamic performance (48.8dBFS SNR @ fIN = 175MHz) while
consuming less than 330mW. Features include an over-range
indicator and a selectable divide-by-2 input clock divider. The
KAD2708L is one member of a pin-compatible family offering 8
and 10-bit ADCs with sample rates from 105MSPS to
350MSPS and LVDS-compatible or LVCMOS outputs (Table 1).
This family of products is available in 68 Ld RoHS-compliant
QFN packages with exposed paddle. Performance is specified
over the full industrial temperature range (-40°C to +85°C).
评论(0)
发评论
下载排行榜
