5962-0625501QXC pdf datasheet
消耗积分:3 | 格式:rar | 大小:333 | 2009-02-10
分享资料个
The 5962-0625501QXC is a fully DSCC SMD compliant part
and the SMD data sheet is available on the DSCC website
(http://www.elecfans.com).
The 5962-0625501QXC is electrically equivalent to the
EL5106. Reference equivalent “EL” data sheet for additional
information. The 5962-0625501QXC is a fixed gain amplifier
with a bandwidth of 350MHz. This amplifier is ideal for
today’s high speed video and monitor applications. It
features internal gain setting resistors and can be configured
in a gain of +1, -1 or +2.
With a supply current of just 1.5mA and the ability to run
from a single supply voltage from 5V to 12V, these amplifiers
are also ideal for handheld, portable or battery powered
equipment.
The 5962-0625501QXC has an enable and disable function
to reduce the supply current to 25μA typical. Allowing the CE
pin to float or applying a low logic level will enable the amplifier.
评论(0)
发评论
下载排行榜
