5962-0625601QXC, 5962-0625602Q
消耗积分:2 | 格式:rar | 大小:333 | 2009-02-10
分享资料个
The 5962-0625601QXC and 5962-0625602QXC are fully
DSCC SMD compliant parts and the SMD data sheets are
available on the DSCC website (http://www.elecfans.com). The 5962-0625601QXC is
electrically equivalent to the EL5166, the 5962-0625602QXC
is electrically equivalent to the EL5167. Reference
equivalent “EL” data sheet for additional information. The
amplifiers are of the current feedback variety and exhibit a
very high bandwidth of 1.4GHz at AV = +1 and 800MHz at
AV = +2. This makes these amplifiers ideal for today's high
speed video and monitor applications, as well as a number
of RF and IF frequency designs.
With a supply current of just 12mA and the ability to run from
a single supply voltage from 5V to 12V, these amplifiers offer
very high performance for little power consumption.
The 5962-0625601QXC also incorporates an enable and
disable function to reduce the supply current to 13μA typical
per amplifier. Allowing the CE pin to float or applying a low
logic level will enable the amplifier.
评论(0)
发评论
下载排行榜
