基于DC1811A-KIT直流到直流多输出电源的参考设计
消耗积分:2 | 格式:pdf | 大小:795.4KB | 2021-07-14
分享资料个
说明
  • DC1811A-KIT, is a dual-output, high efficiency, high density, module regulator with 4.5V to 26.5V input range. Each output can supply 13A maximum load current. The demo board has a LTM4676 module regulator, which is a dual 13A or single 26A step-down regulator with PMBUs power system management. The DC1811A powers up to default settings and produces power based on configuration resistors without the need for any serial bus communication
主要特色
  • Conversion Type
    DC to DC
  • Input Voltage
    4.5 to 26.5 V
  • Output Voltage
    0.5 to 4|0.5 to 5.4 V
  • Output Current
    13 A
  • Efficiency
    86.23 %
  • Topology
    Buck
评论(0)
发评论
下载排行榜
