电阻测量方法的研究-The Research on Measuring Method of Resistance
详细分析了1 k11- 500 Gf电阻各量程的分辨率和测量电路输出信号范围,并以此为依据设计了实用的电路系统。同时给出体的测量方法如下:首先判断电阻的范围,将放大器切换到合适的量程;放大后的电压信号经A/D转换送给单片机计算电阻值;根据各自量程的标准电阻值及其测量值之差进行动态校正。该方法消除了噪声对测量精度的影响。测试结果表明:在全量程范围内,最小测量误差为0.03%,最大测量误差为0.8%。
关键词:电阻测量 多量程 测量 分辨率 动态校正
Abstract;T her esolutiona ndo utputsi gnalof ea chr angefr om1 W to5 00(;nresistancea rea nalyzed.T husth ep racticalci rcuitsy stemi sd esigned.
The concrete measuring method is given as folows: Firstly, the unknown resistance range is judged approximately; then, switch the
amplifier to an appropriate measurement range; the voltage signal output from amplifier is transmitted to single chip computer through A/D converter,
the resistance value is calculated场the computer. Dynamic adjustment is conducted on the difference between the standard resistance of
each range and the measurement. This method eliminates the noise effect on precision of measurement. Test results in ful measurement rangeshow
thatth em inimum measuremente rrori s0 .03%,them aximum erroris 0 .8% .
Keywords:M easurementof re sistance Measurementw ithm ultipler anges Resolution Dynamica djustmen
