基于OM1320STM_Typical Application直流到直流单输出电源的参考设计
消耗积分:2 | 格式:pdf | 大小:38.37KB | 2021-08-13
分享资料个
说明
  • Typical Application for OM1320STM 1.5A Positive Voltage Regulator. These three terminal positive regulators are supplied in hermetically sealed packages. All protective features are designed into the circuit, including thermal shutdown, current-limiting, and safe-area control. With heat sinking, these devices can deliver up to 1.5A of output current. The LCC-20 device is limited to 1.5A. The unit also features output voltages that can be fixed from 1.2V to 37V using external resistors
主要特色
  • Conversion Type
    DC to DC
  • Topology
    LDO
评论(0)
发评论
下载排行榜
