pci2050bipdv/PCI2050B pdf data
消耗积分:5 | 格式:rar | 大小:333 | 2009-02-17
张磊
分享资料个
The Texas Instruments PCI2050B PCI-to-PCI bridge provides a high performance connection path between two
peripheral component interconnect (PCI) buses operating at a maximum bus frequency of 66-MHz. Transactions
occur between masters on one and targets on another PCI bus, and the PCI2050B bridge allows bridged transactions
to occur concurrently on both buses. The bridge supports burst mode transfers to maximize data throughput, and the
two bus traffic paths through the bridge act independently.
The PCI2050B bridge is compliant with the PCI Local Bus Specification, and can be used to overcome the electrical
loading limits of 10 devices per PCI bus and one PCI device per extension slot by creating hierarchical buses. The
PCI2050B provides two-tier internal arbitration for up to nine secondary bus masters and may be implemented with
an external bus arbiter.
The CompactPCI hot-swap extended PCI capability makes the PCI2050B bridge an ideal solution for multifunction
compact PCI cards and adapting single function cards to hot-swap compliance.
The PCI2050B bridge is compliant with the PCI-to-PCI Bridge Specification (Revision 1.1). The PCI2050B bridge
provides compliance for PCI Bus Power Management Interface Specification (Revision 1.1). The PCI2050B bridge
has been designed to lead the industry in power conservation and data throughput. An advanced CMOS process
achieves low system power consumption while operating at PCI clock rates up to 66-MHz.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
