MAX2108 pdf datasheet (direct-
消耗积分:5 | 格式:rar | 大小:344 | 2009-02-22
分享资料个
The MAX2108 is a low-cost direct-conversion tuner IC designed for use in digital direct-broadcast satellite (DBS) television set-top box units and microwave links. Its direct-conversion architecture reduces system cost compared to devices with IF-based architectures.
The MAX2108 directly tunes L-band signals to baseband using a broadband I/Q downconverter. The operating frequency range spans from 950MHz to 2150MHz. The IC includes a low-noise amplifier (LNA) with gain control, two downconverter mixers with output buffers, a 90° quadrature generator, and a divide-by 32/33 prescaler.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
