采用一种高存储效率的改进时域有限差分算法对圆柱形单极天线进行了分析,得到了近场、远场的瞬态分布和天线辐射的物理过程;与普通时域有限差分算法的分析结果进行比较,所得的数值结果具有较高精度,节省了存储量和计算时间。
关 键 词 时域有限差分算法; 数值分析; 存储效率; 天线辐射
Abstract A modified version of the finite-difference time-domain method with increased memory efficiency is applied to the computation of the radiation from a cylindrical monopole. And the graphical displays presented for the transient near-zone and far-zone radiation from the antenna provide physical insight into the radiation process. The novel approach compared with the normal finite-difference time-domain has higher efficiency.
Key words finite-difference time-domain method; numerical analysis; memory-efficient; radiation from antennas
下载资料需要登录,并消耗一定积分。
