实用网络中主动网执行环境的设计及实现
消耗积分:3 | 格式:rar | 大小:233 | 2009-02-28
分享资料个
在分析典型的现有主动网系统的基础上,借鉴Protocol Booster的设计思路,提出了一种新的面向实用网络环境的主动网执行环境模型。该模型在充分考虑性能(包处理效率)的基础上,采用类似Protocol Booster的增量实现方法,易于扩展并且与现有网络完全兼容,并给出了在Linux平台下该模型的实现。
关 键 词 主动网; 执行环境; Protocol Booster; NetFilter
Abstract In this paper, the experimental active networks execution environments are analyzed and a novel execution environment model is given, which aims at the practicability in nowaday networks(Internet). This execution environment model uses a protocol-booster-like increment, which is easy to be extended and completely compatible with nowaday networks. At last, based on Linux operation system, an implementation frame of this execution environment model is given.
Key words active networks; execution environment; Protocol Booster; NetFilter
评论(0)
发评论
下载排行榜
