USB设备可在HomeKit中使用的插件
消耗积分:0 | 格式:zip | 大小:0.00 MB | 2022-04-21
笑尽往事
分享资料个
授权协议 MIT License
开发语言 JavaScript
操作系统 跨平台
软件类型 开源软件
所属分类 其他开源物联网
软件简介
homebridge-aircontrol-mini
A HomeBridge Plugin making the TFA-Dostmann AirCO2ntrol Mini CO2 Monitor measurment USB device availible in HomeKit.
Installation
For use on an Ubuntu/Debian style Linux:
sudo apt-get install build-essential libudev-dev
sudo npm install -g --unsafe-perm homebridge-aircontrol-mini
To allow homebridge to run without beeing root or using sudo a udev Rule needs to be added.
Create /etc/udev/rules.d/23-homebridge.rules and put in the following line, where you replace homebridge with the group of the user running homebridge on your system (e.g. pi on a raspian):
, ATTR{idVendor}, ATTR{idProduct}, ,
Afterwards reload the rules with udevadm control --reload and replug the USB plug of your AirControl Mini.
Sample Config (Excerpt)
Configured as part of your homebridge configuration.
  • accessory: Needs to be aircontrol-mini
  • name: Required, String; You need to configure the name of your accessory.
  • co2_warning_level: Optional, Number, Default 1200; Configure the level (in ppm) at which the CO2 is detected as abnormal (default 1200ppm, same as red LED level according to the device manual).
In addition to this you need to connect the device to your machine running homebridge.
  "bridge": {
  "accessories": [
      "accessory": "aircontrol-mini",
      "name": "Living Room CO2",
      "co2_warning_level": 1200
评论(0)
发评论
下载排行榜
