Digitemp Junior – An RS-232 Port-Powered Digital Thermometer
Digitemp Jr. is a device that is designed to measure
and report ambient temperature. When connected to
an RS-232 port on any PC, it will periodically measure
and report in ASCII form the ambient temperature in
degrees Celsius. These temperature readings can be
monitored with any terminal program. If the terminal
program supports capture to disk, the temperature
readings can be saved to disk for further analysis with
a spreadsheet program or other data analysis tool. The
simple ASCII output format of Digitemp Jr. makes it rel-
atively easy to write custom software for receiving,
recording, and analyzing ambient temperature data.
Best of all, Digitemp Jr. requires no external power sup-
plies or batteries. It is powered directly by the RS-232 port.
全部4条评论
